Blacknoise
Corsair
B12x-PS-BL PWM ARGB
LL140 RGB
120 g
210 g
600 U/min
1500 U/min
1300 U/min
58.1 CFM
51.5 CFM
98.7 m³/h
87.5 m³/h
1.80 mmH2O
1.52 mmH2O
21.2 dBA
25.0 dBA
Halbtransparent
3.3 V
2.9 V
386 U/min
226 U/min
570 U/min
378 U/min
1491 U/min
1319 U/min
36.6 CFM
+23.0 %
45.0 CFM
23.5 CFM
+20.5 %
28.4 CFM
23.9 CFM
+2.2 %
24.5 CFM
22.8 CFM
+16.1 %
26.4 CFM
62.2 m³/h
+23.0 %
76.5 m³/h
40.0 m³/h
+20.5 %
48.2 m³/h
39.8 m³/h
+4.5 %
41.6 m³/h
38.7 m³/h
+16.0 %
44.9 m³/h
1.12 mmH2O
+86.7 %
0.60 mmH2O
+42.0 %
+22.0 %
+16.4 %
0.11 hPa
+83.3 %
+40.0 %
+20.0 %
+16.7 %
38.7
-8.8 %
35.3
37.9
-2.6 %
36.9
39.1
-13.0 %
34
37
-5.9 %
34.8
