Lian Li
Cooler Master
Uni Fan AL V2 120
Masterfan MF120 Halo
28 mm
240 g
180 g
250 U/min
650 U/min
1800 U/min
0.7 W
2.1 W
77.3 CFM
47.2 CFM
131.3 m³/h
2.97 mmH2O
28.7 dBA
30.0 dBA
Einzelreview
Grau
Halbtransparent
3.0 V
3.3 V
762 U/min
166 U/min
749 U/min
590 U/min
297 U/min
198 U/min
1792 U/min
820 U/min
48.2 CFM
+94.6 %
24.8 CFM
40.2 CFM
+102.1 %
19.9 CFM
30.1 CFM
+48.7 %
20.2 CFM
41.2 CFM
+139.0 %
17.2 CFM
81.9 m³/h
+94.5 %
42.1 m³/h
68.3 m³/h
+102.1 %
33.8 m³/h
51.1 m³/h
+62.9 %
31.4 m³/h
70.0 m³/h
+138.9 %
29.3 m³/h
1.73 mmH2O
+333.4 %
0.40 mmH2O
1.53 mmH2O
+88.9 %
1.02 mmH2O
+155.0 %
0.40 mmH2O
1.63 mmH2O
+307.5 %
0.40 mmH2O
0.17 hPa
+325.0 %
0.15 hPa
+87.5 %
+150.0 %
0.16 hPa
+300.0 %
31.5
-16.7 %
37.8
29.1
-20.1 %
36.4
30.5
-16.4 %
36.5
30.1
-15.4 %
35.6
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
