Lian Li
Corsair
Uni Fan AL V2 120
QL120 RGB
28 mm
240 g
163 g
250 U/min
500 U/min
1500 U/min
0.7 W
2.1 W
77.3 CFM
41.8 CFM
131.3 m³/h
2.97 mmH2O
1.55 mmH2O
28.7 dBA
26.0 dBA
Einzelreview
Silber
Halbtransparent
3.0 V
3.0 V
762 U/min
245 U/min
749 U/min
472 U/min
297 U/min
198 U/min
1600 U/min
820 U/min
48.2 CFM
+73.5 %
27.8 CFM
40.2 CFM
+95.1 %
20.6 CFM
30.1 CFM
+56.9 %
19.2 CFM
41.2 CFM
+139.0 %
17.2 CFM
81.9 m³/h
+73.5 %
47.2 m³/h
68.3 m³/h
+95.1 %
35.0 m³/h
51.1 m³/h
+56.9 %
32.6 m³/h
70.0 m³/h
+138.9 %
29.3 m³/h
1.73 mmH2O
+71.6 %
1.01 mmH2O
1.53 mmH2O
+206.0 %
1.02 mmH2O
+104.0 %
1.63 mmH2O
+307.5 %
0.40 mmH2O
0.17 hPa
+70.0 %
0.15 hPa
+200.0 %
+100.0 %
0.16 hPa
+300.0 %
31.5
-18.0 %
38.4
29.1
-24.0 %
38.3
30.5
-15.0 %
35.9
30.1
-15.9 %
35.8
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
