Lian Li
Lian Li
Uni Fan AL V2 120
UNI FAN SL120 ARGB
28 mm
240 g
232 g
250 U/min
800 U/min
1900 U/min
0.7 W
2.1 W
77.3 CFM
58.5 CFM
131.3 m³/h
99.5 m³/h
2.97 mmH2O
1.67 mmH2O
28.7 dBA
31.0 dBA
Einzelreview
Silber
3.0 V
2.4 V
762 U/min
412 U/min
749 U/min
98 U/min
297 U/min
198 U/min
1828 U/min
820 U/min
48.2 CFM
+107.4 %
23.2 CFM
40.2 CFM
+127.0 %
17.7 CFM
30.1 CFM
+90.1 %
15.8 CFM
41.2 CFM
+169.3 %
15.3 CFM
81.9 m³/h
+107.3 %
39.5 m³/h
68.3 m³/h
+126.9 %
30.1 m³/h
51.1 m³/h
+90.1 %
26.9 m³/h
70.0 m³/h
+169.2 %
26.0 m³/h
1.73 mmH2O
+333.4 %
0.40 mmH2O
1.53 mmH2O
+282.5 %
0.40 mmH2O
1.02 mmH2O
+155.0 %
0.40 mmH2O
1.63 mmH2O
+307.5 %
0.40 mmH2O
0.17 hPa
+325.0 %
0.15 hPa
+275.0 %
+150.0 %
0.16 hPa
+300.0 %
31.5
-18.8 %
38.8
29.1
-20.7 %
36.7
30.5
-15.5 %
36.1
30.1
-13.0 %
34.6
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
