Lian Li
Alphacool
Uni Fan AL V2 120
Eiszyklon Aurora Lux Pro ARGB
28 mm
240 g
200 g
250 U/min
600 U/min
1500 U/min
0.7 W
2.1 W
77.3 CFM
58.3 CFM
131.3 m³/h
99.3 m³/h
2.97 mmH2O
1.60 mmH2O
28.7 dBA
38.0 dBA
Einzelreview
3.0 V
3.3 V
2.9 V
762 U/min
316 U/min
749 U/min
393 U/min
297 U/min
198 U/min
1499 U/min
820 U/min
48.2 CFM
+4.9 %
46.0 CFM
40.2 CFM
+62.3 %
24.8 CFM
30.1 CFM
+42.1 %
21.2 CFM
41.2 CFM
+70.7 %
24.1 CFM
81.9 m³/h
+4.9 %
78.1 m³/h
68.3 m³/h
+62.2 %
42.1 m³/h
51.1 m³/h
+42.1 %
36.0 m³/h
70.0 m³/h
+70.7 %
41.0 m³/h
1.73 mmH2O
+144.2 %
1.53 mmH2O
+282.5 %
0.40 mmH2O
1.02 mmH2O
+104.0 %
1.63 mmH2O
+307.5 %
0.40 mmH2O
0.17 hPa
+142.9 %
0.15 hPa
+275.0 %
+100.0 %
0.16 hPa
+300.0 %
31.5
-8.4 %
34.4
29.1
-14.7 %
34.1
30.5
-7.9 %
33.1
30.1
-7.4 %
32.5
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
