Corsair
Arctic
QL120 RGB
P12 PWM PST RGB 0dB
163 g
159 g
500 U/min
1500 U/min
41.8 CFM
48.8 CFM
82.9 m³/h
1.55 mmH2O
1.85 mmH2O
26.0 dBA
Silber
Grau
Halbtransparent
Halbtransparent
3.0 V
4.0 V
2.9 V
245 U/min
380 U/min
472 U/min
532 U/min
1600 U/min
1985 U/min
27.8 CFM
+15.7 %
32.1 CFM
20.6 CFM
+16.3 %
23.9 CFM
19.2 CFM
+20.0 %
23.0 CFM
17.2 CFM
+28.0 %
22.1 CFM
47.2 m³/h
+15.7 %
54.6 m³/h
35.0 m³/h
+16.3 %
40.7 m³/h
32.6 m³/h
+19.9 %
39.1 m³/h
29.3 m³/h
+28.0 %
37.5 m³/h
1.01 mmH2O
+24.7 %
+22.0 %
+22.0 %
0.40 mmH2O
+52.5 %
+25.0 %
+20.0 %
+20.0 %
+50.0 %
38.4
-12.0 %
33.8
38.3
-17.5 %
31.6
35.9
-8.9 %
32.7
35.8
-10.3 %
32.1
