Corsair
Blacknoise
QL120 RGB
B12x-PS-BL PWM ARGB
163 g
120 g
500 U/min
1500 U/min
1500 U/min
41.8 CFM
58.1 CFM
98.7 m³/h
1.55 mmH2O
1.80 mmH2O
26.0 dBA
21.2 dBA
Silber
Halbtransparent
3.0 V
3.3 V
245 U/min
386 U/min
472 U/min
570 U/min
1600 U/min
1491 U/min
27.8 CFM
+31.7 %
36.6 CFM
20.6 CFM
+14.3 %
23.5 CFM
19.2 CFM
+24.9 %
23.9 CFM
17.2 CFM
+32.1 %
22.8 CFM
47.2 m³/h
+31.8 %
62.2 m³/h
35.0 m³/h
+14.3 %
40.0 m³/h
32.6 m³/h
+22.1 %
39.8 m³/h
29.3 m³/h
+32.1 %
38.7 m³/h
1.01 mmH2O
+10.9 %
1.12 mmH2O
+42.0 %
+22.0 %
0.40 mmH2O
+77.5 %
+10.0 %
0.11 hPa
+40.0 %
+20.0 %
+75.0 %
38.4
-0.8 %
38.7
38.3
-1.0 %
37.9
35.9
-8.2 %
39.1
35.8
-3.2 %
37
