Corsair
Arctic
QL120 RGB
P12 PWM
163 g
139 g
500 U/min
200 U/min
1500 U/min
1800 U/min
41.8 CFM
56.3 CFM
1.55 mmH2O
2.20 mmH2O
26.0 dBA
Silber
Silber
Halbtransparent
3.0 V
3.0 V
245 U/min
207 U/min
472 U/min
547 U/min
1600 U/min
1748 U/min
27.8 CFM
+20.7 %
33.5 CFM
20.6 CFM
+12.8 %
23.2 CFM
19.2 CFM
+20.0 %
23.0 CFM
17.2 CFM
+24.9 %
21.5 CFM
47.2 m³/h
+20.8 %
57.0 m³/h
35.0 m³/h
+12.9 %
39.5 m³/h
32.6 m³/h
+19.9 %
39.1 m³/h
29.3 m³/h
+24.9 %
36.6 m³/h
1.01 mmH2O
+102.0 %
+22.0 %
0.5
0.5
0.40 mmH2O
+52.5 %
+100.0 %
+20.0 %
0.05
0.05
+50.0 %
38.4
-4.4 %
36.7
38.3
-9.4 %
34.7
35.9
-3.3 %
34.7
35.8
-3.9 %
34.4
