Corsair
Lian Li
QL120 RGB
Uni Fan AL V2 120
28 mm
163 g
240 g
500 U/min
250 U/min
1500 U/min
0.7 W
2.1 W
41.8 CFM
77.3 CFM
131.3 m³/h
1.55 mmH2O
2.97 mmH2O
26.0 dBA
28.7 dBA
Einzelreview
Silber
Halbtransparent
3.0 V
3.0 V
245 U/min
762 U/min
472 U/min
749 U/min
297 U/min
198 U/min
1600 U/min
820 U/min
27.8 CFM
+73.5 %
48.2 CFM
20.6 CFM
+95.1 %
40.2 CFM
19.2 CFM
+56.9 %
30.1 CFM
17.2 CFM
+139.0 %
41.2 CFM
47.2 m³/h
+73.5 %
81.9 m³/h
35.0 m³/h
+95.1 %
68.3 m³/h
32.6 m³/h
+56.9 %
51.1 m³/h
29.3 m³/h
+138.9 %
70.0 m³/h
1.01 mmH2O
+71.6 %
1.73 mmH2O
+206.0 %
1.53 mmH2O
+104.0 %
1.02 mmH2O
0.40 mmH2O
+307.5 %
1.63 mmH2O
+70.0 %
0.17 hPa
+200.0 %
0.15 hPa
+100.0 %
+300.0 %
0.16 hPa
38.4
-18.0 %
31.5
38.3
-24.0 %
29.1
35.9
-15.0 %
30.5
35.8
-15.9 %
30.1
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
