Blacknoise
Blacknoise
NB-eLoop X PWM B12xP ARGB
B12x-PS-BL PWM ARGB
120 g
120 g
400 U/min
1500 U/min
77.9 CFM
58.1 CFM
132.4 m³/h
98.7 m³/h
3.02 mmH2O
1.80 mmH2O
28.4 dBA
21.2 dBA
Grau
3.4 V
3.3 V
294 U/min
386 U/min
138 U/min
570 U/min
2002 U/min
1491 U/min
40.5 CFM
+10.8 %
36.6 CFM
24.9 CFM
+5.7 %
23.5 CFM
23.0 CFM
+4.1 %
23.9 CFM
21.0 CFM
+8.4 %
22.8 CFM
68.9 m³/h
+10.8 %
62.2 m³/h
42.3 m³/h
+5.7 %
40.0 m³/h
39.1 m³/h
+1.8 %
39.8 m³/h
35.7 m³/h
+8.4 %
38.7 m³/h
1.43 mmH2O
+27.7 %
1.12 mmH2O
+14.1 %
0.61
0.61
+42.0 %
0.14 hPa
+27.3 %
0.11 hPa
+14.3 %
0.06
0.06
+40.0 %
34.4
-11.1 %
38.7
36.5
-3.7 %
37.9
35.9
-8.2 %
39.1
36.1
-2.4 %
37
