Lian Li
NZXT
UNI FAN SL120 ARGB
F120 RGB
26 mm
232 g
205 g
800 U/min
500 U/min
1900 U/min
1800 U/min
0.4 W
1.8 W
58.5 CFM
50.2 CFM
99.5 m³/h
85.2 m³/h
1.67 mmH2O
2.70 mmH2O
31.0 dBA
27.5 dBA
Silber
4.7 V
2.4 V
4.4 V
412 U/min
827 U/min
98 U/min
703 U/min
1828 U/min
1924 U/min
447 U/min
23.2 CFM
+4.1 %
24.2 CFM
17.7 CFM
+7.0 %
18.9 CFM
15.8 CFM
+21.8 %
13.0 CFM
15.3 CFM
+22.3 %
18.7 CFM
39.5 m³/h
+4.1 %
41.1 m³/h
30.1 m³/h
+7.0 %
32.2 m³/h
26.9 m³/h
+21.7 %
22.1 m³/h
26.0 m³/h
+22.3 %
31.8 m³/h
0.40 mmH2O
+127.5 %
0.91 mmH2O
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
+125.0 %
0.09 hPa
+100.0 %
+100.0 %
+100.0 %
38.8
-36.1 %
24.8
36.7
-17.2 %
30.4
36.1
-10.2 %
32.4
34.6
-14.5 %
29.6
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
