Blacknoise
Corsair
B14x-P-BL PWM ARGB
LL140 RGB
202 g
210 g
600 U/min
1500 U/min
1300 U/min
0.5 W
2.9 W
110.0 CFM
51.5 CFM
186.0 m³/h
87.5 m³/h
2.30 mmH2O
1.52 mmH2O
29.6 dBA
25.0 dBA
Halbtransparent
4.3 V
2.9 V
335 U/min
226 U/min
154 U/min
378 U/min
1487 U/min
1319 U/min
60.3 CFM
+33.9 %
45.0 CFM
33.2 CFM
+17.2 %
28.4 CFM
32.3 CFM
+32.0 %
24.5 CFM
33.2 CFM
+25.8 %
26.4 CFM
102.4 m³/h
+33.9 %
76.5 m³/h
56.5 m³/h
+17.2 %
48.2 m³/h
54.9 m³/h
+32.0 %
41.6 m³/h
56.5 m³/h
+25.8 %
44.9 m³/h
1.32 mmH2O
+120.0 %
0.60 mmH2O
1.32 mmH2O
+164.0 %
1.01 mmH2O
+102.0 %
1.22 mmH2O
+100.0 %
0.13 hPa
+116.7 %
0.13 hPa
+160.0 %
+100.0 %
0.12 hPa
+100.0 %
33.7
-4.5 %
35.3
37.4
-1.3 %
36.9
36.6
-7.1 %
34
36
-3.3 %
34.8
