Thermaltake
Blacknoise
B12x-PS-BL PWM ARGB
212 g
120 g
500 U/min
1500 U/min
58.4 CFM
58.1 CFM
99.1 m³/h
98.7 m³/h
2.41 mmH2O
1.80 mmH2O
22.3 dBA
21.2 dBA
Grau
3.3 V
391 U/min
386 U/min
413 U/min
570 U/min
1950 U/min
1491 U/min
33.2 CFM
+10.3 %
36.6 CFM
25.2 CFM
+7.0 %
23.5 CFM
24.5 CFM
+2.2 %
23.9 CFM
20.8 CFM
+9.3 %
22.8 CFM
56.4 m³/h
+10.3 %
62.2 m³/h
42.8 m³/h
+7.0 %
40.0 m³/h
41.6 m³/h
+4.5 %
39.8 m³/h
35.4 m³/h
+9.4 %
38.7 m³/h
1.84 mmH2O
+64.3 %
1.12 mmH2O
+14.1 %
+22.0 %
0.40 mmH2O
+77.5 %
0.18 hPa
+64.0 %
0.11 hPa
+13.5 %
+22.4 %
+78.5 %
37.4
-3.4 %
38.7
36.5
-3.7 %
37.9
36
-7.9 %
39.1
36.2
-2.2 %
37
