Blacknoise
NZXT
B12x-PS-BL PWM ARGB
F120 RGB
26 mm
120 g
205 g
500 U/min
1500 U/min
1800 U/min
0.4 W
1.8 W
58.1 CFM
50.2 CFM
98.7 m³/h
85.2 m³/h
1.80 mmH2O
2.70 mmH2O
21.2 dBA
27.5 dBA
3.3 V
4.7 V
4.4 V
386 U/min
827 U/min
570 U/min
703 U/min
1491 U/min
1924 U/min
447 U/min
36.6 CFM
+51.3 %
24.2 CFM
23.5 CFM
+24.2 %
18.9 CFM
23.9 CFM
+84.2 %
13.0 CFM
22.8 CFM
+21.7 %
18.7 CFM
62.2 m³/h
+51.3 %
41.1 m³/h
40.0 m³/h
+24.2 %
32.2 m³/h
39.8 m³/h
+80.1 %
22.1 m³/h
38.7 m³/h
+21.7 %
31.8 m³/h
1.12 mmH2O
+23.1 %
0.91 mmH2O
+14.1 %
+32.8 %
+14.1 %
0.11 hPa
+22.2 %
0.09 hPa
+14.3 %
+33.3 %
+14.3 %
38.7
-35.9 %
24.8
37.9
-19.8 %
30.4
39.1
-17.1 %
32.4
37
-20.0 %
29.6
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
