Lian Li
Arctic
Uni Fan AL V2 120
P12 PWM
28 mm
240 g
139 g
250 U/min
200 U/min
1800 U/min
0.7 W
2.1 W
77.3 CFM
56.3 CFM
131.3 m³/h
2.97 mmH2O
2.20 mmH2O
28.7 dBA
Einzelreview
Silber
3.0 V
3.0 V
762 U/min
207 U/min
749 U/min
547 U/min
297 U/min
198 U/min
1748 U/min
820 U/min
48.2 CFM
+43.7 %
33.5 CFM
40.2 CFM
+73.0 %
23.2 CFM
30.1 CFM
+30.8 %
23.0 CFM
41.2 CFM
+91.3 %
21.5 CFM
81.9 m³/h
+43.7 %
57.0 m³/h
68.3 m³/h
+72.9 %
39.5 m³/h
51.1 m³/h
+30.8 %
39.1 m³/h
70.0 m³/h
+91.3 %
36.6 m³/h
1.73 mmH2O
+246.7 %
1.53 mmH2O
+150.8 %
1.02 mmH2O
+104.0 %
1.63 mmH2O
+167.2 %
0.17 hPa
+240.0 %
0.15 hPa
+150.0 %
+100.0 %
0.16 hPa
+166.7 %
31.5
-14.2 %
36.7
29.1
-16.1 %
34.7
30.5
-12.1 %
34.7
30.1
-12.5 %
34.4
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
