I have the XFX Qick probably works the same. For some reason my card only goes to like 1300rpm by default. Which is really only like 25% fan speed.Moin, I am currently optimizing my RX 6600XT, and I have the following problems ...
1. The memory of my WQHD monitor does not clock down, I got the memory from the boost to about 1076 MHz with an OC of my monitor from 75hz to 76hz, but that's not quite the solution.
2. The fan curve of XFX is set much too quiet, so the card is 80 ° C / 95 ° C hotspot with about 42% fan, how do I set it that the card runs at 65 ° C with 1980RPM / 47% and can reach a maximum temperature of 75 ° C?
3. In a tab you can set the voltage from the memory, I run 1200mV at normal clock rate and 2075MHz memory, is that correct or is it just a part of the voltage?
4. Does flashing an edited BIOS work in the meantime?
As far as I can tell, [USER = 87] @hellm [/ USER] does the MPT is that correct?
Thank you for your answers ;-)
The default memory voltage in MPT should be 1.35v at stock speeds. It runs so cool at under 60c already, I don't see a reason to undervolt it. Don't change the SOC voltage by accident. HWinfo shows memory temperature. It's the only app I found that shows it.
