Question AMD Radeon Pro W5700 for mining ethereum
nivrij
I am contemplating about buying this card because someone is offering this to me for a cheaper price here where I live. From my understanding, this card is just the "professional" / "workstation" equivalent of RX 5700 XT.
Any thoughts on this card? Has anyone here actually used this for mining? Does anyone know what the hashrate is? Can an unlocked BIOS be flashed on this GPU?
I believe not now, first please use the unlocked vbios file in the kindly attached link below, it is already modified and ready to use for mining as well,
I'm glad to report that the flashing was successful! The memory temps, GPU clock speed and power consumption are now much lower. Only things left to figure out are how to enable the MSI afterburner sliders and PhoenixMiner to recognize and apply the custom card settings I set through the CMD parameters.
Thank you very much!
It is easy, I am going to do that for you and send you another vbios.
This was a very interesting thread. So would this work on the W5500? Can you post an unlocked vbios for it?
I received the W5500 and it worked out of the box in Win 10 running Adrenalin 21.2.2 drivers using NiceHash with the Phoenix Miner plugin, I am getting an average of 25 MH/s using 85W of GPU power. Attached are screenshots and the stock vbios captured using ATI Flash 2.93 . Can you see if any improvements can be made with an unlocked vbios? Thanks!
  • AMD W5500 Stock_3646.zip
Hi,
I just ordered a W5700 recently. Unfortunately I have to a while wait since there's still more than two weeks for the delivery time. I'm very gladful for this thread and @Mini_Me 's inputs.
nivrij What's your latest mining results? Core, memory clocks, underclock voltages, hashrates at all?
curious about the hashrate after the bios mod. on both W5500 and W5700, Is it a big difference? I run HiveOS and i would like my W5700 cards to work with the OC settings.
  • Like
Bewertungen: MfA
Use phoenixminer and you can change the settings without a new BIOS.
PhoenixMiner.exe -pool eu1.ethermine.org:4444 -pool2 us1.ethermine.org:4444 -wal 0xxxxxxxxxxxxxxxxxxxxxx.x -proto 3 -gt 126 -tt -81 -cvddc 800 -cclock 1200 -mclock 1815 -mt 1 -mode 1 -lidag 0
Thats my setting for 52,2 MH.
Sapphire 5700 XT nitro+
i was referring to the W5700 its a pro card and those settings are usually locked.
My advice is to use morepowertool to change parameters without modifying the vbios for W5500 as the mean time unlocking the 5500 series is postponed.
Mini_Me thank you for all your help with the W5700s. I was able to update one of my cards to your vbios above, and everything is great expect for the efficiency of the hashing. Do you have any suggestions for what to edit to fix that? It seems like it's usually a sign of instability with the tuning. The power savings is amazing.
  • Like
Bewertungen: MfA
You are welcome and you can test the below,
Core clock, VDD : Memory clock, VDDCI, MVDD, TeamRedMiner Hashrate
~ Samsung and Micron,
- 1330 MHz, 750 mV : 850 (1700/2) MHz, 800 mV, 1350 mV, ~52.10 MH/s,
- 1360 MHz, 760 or 770 mV : 880 (1760/2) MHz, 820 mV, 1350 mV, ~54.10 MH/s,
- 1380 MHz, 770 or 780 mV : 900 (1800/2) MHz, 840 mV, 1350 mV, ~55.30 MH/s,
~ Micron,
- 1415 MHz, 790 or 800 mV : 935 (1870/2) MHz, 875 mV, 1350 mV, ~57.10 MH/s,
- 1430 MHz, 800 or 810 mV : 950 (1900/2) MHz, 890 mV, 1350 mV, ~58.10 MH/s.
Hello, I have a set of Radeon Pro W5700, they have Micron memory and, on HiveOS, they do 50MH/s @ 109W out of the box.
I would like to be able to test other parameters, specially because the RAM runs too hot at that pace, with auto-fan, I need to increase the fan speed manually, or memory runs at 100º.
The BIOS version is
113-D1880201-105
and I checked, your unlocked BIOS is 102.
Can someone tell me the steps to unlock a BIOS? (on other AMD cards) ...
Thank you,
The BIOS version is
113-D1880201-105
Thank you,
Hello and welcome,
Please send your original backup vbios to unlock it.
Hi,
55.XX MH/s. Core clock, memory clock and underclock voltages are default according to the optimized BIOS shared by Mini_Me. PhoenixMiner manual setting of parameters for under/over-clocking/under-volting are not working. MSI sliders are also disabled.
I have a PM to you. Please kindly check your inbox.
Hi
I have 8x W5700 PRO Cards
is this the correct instruction to unlock the wattman limits?
Currently there are no settings for the Wattman in Windows. Only the fans are adjustable.
I would do the following steps
1) backup the original bios with GPU-Z
2) load the original bios with MPT Tool
3) on the Features page set all hooks (except Auto Undervolt, Overclock and Memory).
MPT File SAVE
4) Start Red Bios Eiditor and load the original Bios.
Load the MPT file with the Powerplay tab.
5) save the BIOS
With this you should have a bios to unlock the cards.
Is this correct?
Is a UNLOCK of the ROM necessary before ?
amdvbflash -unlockrom 0
Example
Thanks for the help ;-)
Greetings Stone
  • Like
Bewertungen: MfA
