Question AMD Radeon Pro W5700 for mining ethereum
nivrij
I am contemplating about buying this card because someone is offering this to me for a cheaper price here where I live. From my understanding, this card is just the "professional" / "workstation" equivalent of RX 5700 XT.
Any thoughts on this card? Has anyone here actually used this for mining? Does anyone know what the hashrate is? Can an unlocked BIOS be flashed on this GPU?
hello boys,
i had 1 w5700 micron and 1 samsung
both from dell
if i try to bootstrap them at the reboot they crash the system (black screen and cannot boot anyway)
i had to reflash them by ch341 (eprom programmer)
i use to flash them with the 105 bios modded by minime but nothing to do,black screen and cannot reflash with apu or another pci ex or pci vga card...
i'm not able to recognize which bios i have on my card...they have a long string starting with 117 (tomorrow i will post shot with gpuz)
where i can read the bios version of mine card?
Hi, I have an HP W5700 card with 113-D1880502-101 (Samsung mem). Is it possible to unlock them? Thanks
Hi, I also have an HP W5700 card with 113-D1880502-101 (Samsung mem) too. Is it possible to unlock them plz. Thanks !!!
Can some on post modded bios for W5700 V107
This works on every W5700 i have tried...14 so far. 2 were dell, 12 reference, 0 HP.
It's the AMD reference bios for the 5700XT with the apple straps applied. Works every time.
I get 55Mh @~95W for Samsung. You can push it more if you want...i'm fine with 750/1350/1760 settings and the low wattage.
  • 5700XT_mod_apple.rom
It worked
I initially tried a bunch of the bios that were modded and posted by minime, and didn't have good luck with them. What worked for me was using the AMD reference 5700 XT bios and adding the apple straps. Now i just stick with that regardless of what version the W5700 initially is.
  • Like
Bewertungen: MfA
But when I am trying to flash W5700 V106 it is making the card to brick
Hi huskydawg9! whats max tmem of your w5700? i have 82c tmem, 57 tedge,65 tjct..its too much?
thanks
alex
Hi I picked up a used W5700. Wondering if there is a way to tell if the bios is stock or modified?
GPU-Z shows the bios version as 017.001.000.068.013771
IDK if anyone is still following this post but is anyone mining with the W5700 that has a full 6 or 8 rig of all W5700?
Short question to the modded bios... Do i get video output on the card in windows (are the mini diplayports working), if i flash 5700XT_mod_apple.rom
Thanks for help...
I hoped, that i can use my card later in a Macpro 5.1 with this modded vbios...(under Monterey)
I will do this in a few hours and let you know of the results. I'll just get some sleep now. This whole quandary is starting to take a toll on me mentally considering that I bought this card for $400 and bricked it right away. Lol
No worries, please have a good and enough rest we will continue in another time,
Good night.
