Question GIGABYTE 5700 XT Bios mod fails
AlleyCat
Hi,
I am failing to update Gigabyte 5700 XT. The same procedure updates the BIOS on MSI cards with no problem. I follow the instructions on Igors Lab.
The sign of having trouble with the card bios flash shows in GPU-Z. After flash using amdvbflash the values of GPU and memory frequencies is empty. With stock bios there are Mhz frequencies.
Is there any known problems with flashing Gigabyte cards?
Any suggestions on what other forums I may ask for assistance?
Is it possible that the OEM bios is signed, and any modified bios will be rejected?
If the bios is signed, any tools to resign, or would I need to buy a card from a different vendor?
Thanks,
Alley Cat
The ping is important to the pool server, but what's more important is the actual shares, valid vs stale and invalid which is the final product of mining, connection quality, card stability etc. I see you have around 5% stale shares, me too, it is around 4%. Hiveon pool just isn't working for me. I have 0.8% stale shares on ethermine. So I'll pay the $3 to HiveOs and improve actual paid mining by 3.2%.
I also moved to the Ehtermine pool for the same reason. I have 2-3 stale shares over approx. 380 to 420 / hour.
didn't noticed any change except -1MH/gpu on the software. But my test is slightly different as i'm getting better performance with flash to 5700.
I tried modifying 5700 bios on a 5700 XT but saw no improvement in performance. In my opinion, keeping consistency with modified original bios is preferred for television management, unless I find a noticeable change in performance.
How significant on your system is the performance difference between an XT and non-XT bios?
@Mini_Me, did you find what may be the differences in the bios?
Thanks,
AlleyCat
hi
gays @Mini_Me @AlleyCat @Calathia
i have the reference card with blower Samsung memory
I just copied 1500 No mpt made
It's very unstable
He was transported to a far place, how can it be resolved?
It runs on raveos and I can control it remotely
Need you to give me some help
thank you all
is work
1500-2250
000000000F040000000000007A09000040030000162D170F4400170006060002180000000708080014000000210C07000000010101000101001C1800E02E00000F0F0000B4000000B40000004F5178025A0000000C000A0F150500011F2A0C00B4000000CBF4130FB400000000000000
Out of curiosity, for those that are using HiveOS with AMD 5700 cards, what version of HiveOS are you using? I'm new to HiveOS, but it is my understanding that the 5700 cards are only supported in the Beta version, which is what I'm using (0.6-170@201029). Also, what AMD drivers? I'm using the same drivers that are included in the HiveOS beta (OpenCL 19.30). Can the AMD drivers be updated seperately?
Don't recommend hiveos
There are some problems with their system, and the processing speed is too slow
I used to be a user of hiveos, but now I moved to raveos
How can you ping to various pools and find out which one has best ping? HiveOS has one of its API's at city which is within few hundred kilometers from my hometown. Still my rig pings for that location for 130 ms !!
big pool have some ams service
pool Less delay
Need to test the ping value of various pools to find your own suitable pool
Thanks,
AlleyCat
Hi AlleyCat,
There are no differences in programming, the only difference is the power table values which was made to fit the cards compute units, you will see no difference when flashing the non XT to XT when it comes in mining however in gaming the performance will decreased and the power consumption as well,
Modding the vbios for mining will make both the XT and non XT exactly the same in software and the only real difference is in the hardware as the XT has 4 extra compute units more than the 36 cu of the non XT which means extra 8 to 10 watts,
The problem is not with cards however is with the kernel of the softwares. a kernel can be programed to fully utilize the required compute units to achieve the required level of performance without triggering all the compute units at the same time without fully utilizing them.
I believe this was intentionally set up for some reasons.
hi
It's very unstable
thank you all
is work
1500-2250
Hi,
Below is the right one for Samsung memory, please use it,
- K4Z80325BC (Samsung)
000000000F040000000000007A09000040030000162D170F4400170006060002180000000708080018000000210C07000000010101000101001C1800282300000F0F0000B4000000B40000004F5178025A0000000C000A0F150500011F2A0C00B4000000CBF4130FB400000000000000
Hi,
ok 1500-2250?
Can you give rough parameters?
There is no way to make mpt
Can you give me a detailed configuration including mpt
Copy the above to 1500-2250 without configuring mpt?
The card is not around, I need it to stabilize, I made a mistake before
thank you all
ok 1500-2250?
thank you all
[Updated]
This is the final power table for any RX 5700 card in the kindly attached link below,
- Under Overdrive Limits tab, set:
GFX Maximum Clock 1500 MHz
Memory Maximum Clock 1000 MHz
Power Limit Maximum 0%
Power Limit Minimum 0%
- Under Power and Voltages, set:
Maximum Voltage GFX 850 mV
Maximum Voltage SoC 1150 mV
Minimum Voltage GFX 750 mV
Minimum Voltage SoC 750 mV
Power Limit GPU 140 W
TDC Limit GFX 150 A
TDC Limit SoC 12 A
- Under Frequency tap, set:
GFX Maximum 1150 MHz
Memory DPM 3 - 950 MHz
V. Under Fan tab, set:
Stop Temperature 60° C
Start Temperature 70° C
thx
I will make a mpt test when I get the card later
Thank you very much, leave your eth address
MPT as below,
Minimum Voltage GFX 700 mV
Minimum Voltage SoC 700 mV
TDC Limit GFX 150 A
TDC Limit SoC 12 A
VRAM Timings as below,
Copumy the strap below to (1500 or 1550) MHz strap and to the rest of the straps after it for Samsung memory only,
Core Clock, MHz
Memory Clock, MHz
Core voltage, mV
Memory voltage, mV
How to set that
This whole pool / ping is so confusing...
HiveOS "net-test" gives:
However minerstat sonar gives way faster ping for same paris.hiveos.farm...but cannot ping to http://paris.hiveos.farm. ??? What address do I input to hiveOS flight sheet?? paris.hiveos.farm OR http://paris.hiveos.farm ?
This is wrong, the ping comes from the api server of hiveos
Not a pool
That is, what you get is the ping of the api
You need to find a reasonable ping pool
It is not the api of hiveos
MPT as below,
TDC Limit GFX 150 A
TDC Limit SoC 12 A
I refreshed the bios through raveos in the test
But I don’t have mpt, I just refreshed the bios
I don't know what the parameters are
I am using
Hope it is stable
1390 890 750 800 1275
