Question 5700xt Bios Mod with 5700 non(XT)
w0rtez
Hello,
I found a post about how to get more hashrate from the cards using the bios from a 5700, at my first test i got 56Mh/s with 118w. I did some tweaks and i would like to know if i can get a bit more MH/s with less watts... I'm planning to apply it to my other cards as well if i can get a stable perfomance.
This is my setup right now... In this image only the powercolor flashed with the 5700(non xt) and changes to the tref... others were modded with the original bios nothing were modified on the tref for other cards.
After lowering the vdd to 720 and 1350 to core im getting 2Mh/s less and less watts as well... Can someone tell me where i can get better improvements in MH/s and watts... Check this image for reference.
How can i get better Mh/s and watts... Thanks
Hello,
Hello and welcome,
Please follow the guide in the kindly attached link below,
Hello and welcome,
thanks for your reply. Should i follow this guide with the 5700xt using original rom or using the one from techpowerup of the 5700(non XT)
Thanks again.
No difference as this will not change the compute unit number of your card.
You can use one the settings mentioned in the guide at page 32.
For example:
1380core
770vdd
850vddci
1350mvdd
Would those settings going to increase a lot my watts... thats what im fearing... because with this settings at least when i have tried it jumps... can it be because of the miner as well?
For example:
1380core
770vdd
850vddci
1350mvdd
You need to test the power at the wall, never take HiveOS reading as a solid report.
