Question how to lower memory temp on MSI 5700 XT MECH OC?
raznehb
Hi Masters,
I have a MSI 5700 XT MECH OC, bios modded with OC. The memory temp is so high as always even without OC.
I wull put some and observe. I will updatecyou.. Thanks mini_me
Can you give sample? Memory clock should match the core clock, mvdd etc right?
Please follow the guide in the kindly attached link below,
When i use windows 10 with my 5700xt attached using riser or attached directly to the board, screen goes black, white, gray, red, green and blue. Whats wrong with that?
Have you tried the washer mod (for GPU) or replaced thermal pads for memory? Maybe brand of thermal pads are the issue for memory? I'm having some high memory temps on my Micron cards and I'm gonna pull the card apart and replace the pads on the memory -- and since replacing memory pads will mess up the GPU thermal pad, I'm gonna clean the GPU pad and use paste.
  1. How to FIX ASUS ROG Strix Radeon RX 5700 XT heatsink bad design! – GW Computers Blog (gw-blog.com)
  2. Fixing the RX 5700 XT Cooler for $0.04 | Paste & Washers vs. Thermal Pad - YouTube
  3. We performed the 5700XT Washer + Paste mod... did it help? - YouTube (This is for GPU temps).
  4. Fixing MSI's Design Flaw: Thermal Pad Swap on RX 5700 XT Evoke OC - YouTube (This is for RAM temps).
Personally -- I went ahead and ordered plastic 1MM thick washers, M2 screws, Thermal Grizzly Minus Pad 8 Thermal Pad, 100 × 100 × 1.0 mm, Thermal Grizzly Minus Pad 8 Thermal Pad, 100 × 100 × 2.0 mm, and Thermal Grizzly Kryonaut Thermal Grease Paste - 11.1 Grams.
