10- Keep MorePowerTool running, do not close it and click on Curve tab,
11- Download and Unzip CRU.zip and inside its folder run as Administrator restart64.exe to restart the gpu driver,
https://www.monitortests.com/download/cru/cru-1.4.2.zip
12- Download and run as Administrator, Navi Curve Helper and keep it running,
https://github.com/datspike/navi_curve_helper/releases/download/1.0.2/navi_curve_helper_1.0.2.exe
13- Run AMD Raedon software as Administrator, Click on Manual, Enable GPU tuning, Enable Advanced Control and note down the default parameters of frequencies and voltages under the diagram ,
Now you have opened 3 programs,
14- Copy the Curvature, Vertex and Offset from the Curve tab in MorePowerTool to the Stock curve parameters in the NaviCurveHelper,
15- Copy the frequencies and voltages under the diagram in the AMD Raedon software to the Stock voltage ports, please note that the frequencies in NaviCurveHelper are in GHz and not MHz, E.g.; 800 MHz = 0.800 GHz and the frequencies in the AMD Raedon software should be (800, 1115, 1430) MHz,
16- Now copy the same frequencies from AMD Raedon software to the Modded curve parameters in the NaviCurveHelper and enter the voltages in the Modded voltage ports, left 0.700, middle 0.700, right 0.795,
17- Now copy the Modded curve parameters, Curvature, Vertex and Offset from the NaviCurveHelper to the MorePowerTool ones under the Curve tab and Enable Override AVFS and Click Write SPPT,
18- Now restart the gpu driver again using restart64.exe and Save the . MPT file,
