Hello
I would like to overclock the RTX 4000 Quadro but unfortunately it is not possible to change the GPU clock or RAM clock.
Have tried in Windows with the Afterburner unfortunately without success.
Is there a BIOS MOD for this card?
Or another trick to unlock it so that overclocking is possible.
I know the cards are not designed for this but that's my risk anyway I would take it.
Thanks a lot
Regards Gerd
NVIDIA Quadro RTX 4000 Specs
NVIDIA TU104, 1545 MHz, 2304 Cores, 144 TMUs, 64 ROPs, 8192 MB GDDR6, 1625 MHz, 256 bit
www.techpowerup.com
Thanks a lot
Regards Gerd
