Frage MPT doesn't see RX 6850M XT under any drivers
Sunny1
Hi
I'm running a Legion 7 with RX 6850M XT.
OS Name Microsoft Windows 10 Pro
I've tried both 13/01/2023 drivers from the OEM and the latest ones from AMD.
This is what I got with MPT:
I can upload a BIOS file to it, but it couldn't be written even via the registry edit.
Tried to run it in a compatibility mode as someone successfully did, but no luck as well.
Hi
Hi, have you solved this problem??I have the same problem, I do not know how to solve it.
commenting for thread visiblity and to stay in the loop if a solution for this exists
Hi
hey have you tried nimez drivers?
i have a friend who has a 6850m xt alienware who was able to use mpt with it
