ENG Grafikkarten Testberichte VGA
MSI Radeon RX 5700 XT Evoke OC Edition tested – butter or margarine on bread? | English Review
The MSI RX 5700 Evoke OC Edition was deliberately placed by MSI below the Gaming and Gaming X models in order to be able to operate significantly cheaper on the market. In and of itself, such an endeavour is also very praiseworthy, whereby of course it always depends on where the manufacturer has set the red pen and has to save in order to really hit the price point customer-effectively. That's exactly what we want to test and question today.
Temperature curves and boost clock rates in detail
The cooler is actually quite nice for its size, because even in the closed case the card usually stays below 70 °C. In the open design it’s a cool 67 °C, but it’s also associated with some noise. The overclocking latitude is very manageable with all Navi cards and I didn’t do it out of respect for my ears and the material. The already between 3 and 4 percent higher performance of the factory OC compared to the reference can hardly be topped with reasonable means.
Later on I will talk about the BIOS and my exchange of ideas with MSI, which finally led to an optional silent BIOS, which you can download from the homepage. This time MSI focused on the durability of the card and especially on the use of the only 23.5 cm long card in smaller ITX systems. The temperatures reached are quite suitable for the place of use.
This doesn’t look any different in the stress test, as the waste heat is largely the same as the power consumption is similar to gaming.
Und nun das Ganze noch einmal in nüchternen Zahlen in Tabellenform, wobei ich die Karte fairerweise mit der größeren GeForce RTX 2080 FE vergleiche:
  Start Values
MSI RX 5700 Evoke
Final values
MSI RX 5700 Evoke
Final values
RX 5700 XT Ref.
Open Benchtable
GPU Temperatures
33 °C 66 – 67 °C
85 °C
GPU Clock Rate
1994 MHz 1888 – 1925 MHz
<= 1812 MHz
Room temperature
22 °C 22 °C 22 °C
Closed Case
GPU Temperatures
33 °C 69 – 70 °C
74-75 °C
GPU Clock Rate
1994 MHz 1868 – 1912 MHz
<= 1802 MHz
Air temperatues in the Case
25 °C 45 °C 43 °C
Board Analysis: Infrared Images
The following picture gallery shows all infrared pictures for the gaming loop and the torture loop in open and closed cases.
The stress test adds a maximum of 2 degrees.
In the closed case it gets a little warmer also during gaming.
And in the stress test the voltage converters are a little bit hotter again.
Nevertheless, all this is nothing to think about, because these temperatures are all completely uncritical.
