Grafikkarten News Redaktion VGA
MorePowerTool (MPT) und Red BIOS Editor (RBE) Beta-Programm – MPT 1.3.8 Beta 1 (Debug Overrides and Throttler Control)
MorePowerTool MPT 1.3.8 Beta 2
  • 5600M support
Download
MorePowerTool MPT 1.3.8 Beta 1
  • Advanced Tab – Debug Overrides and Throttler Control
Download
MorePowerTool MPT 1.3.7 Beta 10
  • Windows 11 compatibility (tested with latest build)
  • Smaller improvements and fixes, Library included
Download
MorePowerTool MPT 1.3.7 Beta 9
  • Radeon 5300M added, Radeon Pro W6600 and W6800 added
  • Some smaller improvements and fixes
Download
MorePowerTool MPT 1.3.7 Beta 8
  • Static Voltage Settings for GFX and SoC added in the “Curve” Tab
  • DcBtc Voltage Settings added in the “Curve” Tab
Download
MorePowerTool MPT 1.3.7 Beta 7
  • Source code optimized and shrinked
  • Link DPM Settings added in the “Frequency” Tab
Download
MorePowerTool MPT 1.3.7 Beta 6
  • Linear Droop was moved to the Curve Tab
  • Temperature Dependent Vmin. With temperature, hysteresis and high/low for the minimum voltage of GFX and Soc
  • Donate ETH Address on start screen as finacial support of the developers
Download
MorePowerTool MPT 1.3.7 Beta 5
  • Linear Droop added
  • More Info fore the Voltage Tab:
    GFX – Graphics Clock
    SOC – SOC clock
    Vclk – Part of the UVD decoder package
    Dclk – Part of the UVD decoder package
    DCEFclk – “DCEFCLK – DCE (Display) FCLK – Data fabric (VG20 and later) – Data flow from XGMI, Memory, PCIe” (not changable on RDNA1/2)
    DISPclk – Has to do with driving the connections to the displays
    PIXclk – Related to the display clock leaving the GPU
    PHYclk – Clock speed of the PCB’s PHY pathways between the memory controller and the GDDR6 modules
    DTBclk – Digital Audio part of the encoder?
    Fclk – Fabric clock, related to the SOC
    Fclkboostfreq – (no info yet)
Download
MorePowerTool MPT 1.3.7 Beta 4
  • Some memory improvements
  • VDDCI/MVDD freigeschaltet (RDNA und RDNA2)
  • Radeon VII BIOS load fixed
Download
MorePowerTool MPT 1.3.7 Beta 3
  • RDNA2: Die Einstellungsmöglichkeiten für die Frequenzen wurden erheblich erweitert und so ziemlich alles offengelegt, was offenzulegen ging. Jetzt ist die Community gefragt, um hier die eigenen Erfahrungswerte mit einzubringen, denn jede Karte ist anders.
Download
MorePowerTool 1.3.7 Beta 1
  • RDNA2: Fan Curve Limits wurden aus dem Overdrive übernommen. Die Min- und Max-Werte für die Lüfterkurve kann man nun im Tab “Fan” setzen. Neu hinzu gekommen ist “Auto Acoustic Limit”, das wir bei der Analyse der Radeon Pro W6800 gefunden haben. Diese Karte besitzt dort den Eintrag 1, die Consumer-Karten die 0. Es ist also Spielraum für eigene Tests vorhanden.
  • RDNA2: Voller Radeon Pro W6800 Support. Wichtig: das Aktivieren einiger Funktionen kann von der Radeon Pro Software aktiv unterbunden werden und führt ggf. zu einem fehlenden Bild beim Windows-Start. Hier muss der Eintrag per DDU wieder entfernt werden. nachdem mit einer anderen Karte im System neu gebootet wurde.
  • RDNA2: Alle Änderungen der Version 1.3.6 wurden mit implementiert, die Version 1.3.5 als stabile Version deklariert
169 Antworten
RX480
2,129 Kommentare 1,029 Likes
Danke hellm!
fclk-Boost ist ja mal Was ganz Neues (x)
und
fclk1940 evtl. noch OCen wär ja Hammer
(x) ist Das eher so ein allgemeiner Wert wie GFX-Takt in Frequency?
btw.
Die 6800nonXT scheint default nen kleineren fclk zu haben als die 6900.
Meine getweakten Settings vom alten MPT wurden erkannt.
edit:
Die Änderungen wurden übernommen!
Achtung!
fclk-Boost net angefasst, sondern nur fclk auf 1900 angehoben. (SOC dann passend auf 990x2 mit etwas Abstand)
Als 24/7 minTakt werde ich wohl knapp über fclk-Boost dann GPU 1450 nehmen.
edit2:
War leider net stabil und führte inGame zu nem hardCrash !!!
Das braucht wirklich Zeit und Fingerspitzengefühl, falls sich der Wert für fclk tatsächlich bei der 6800nonXT anheben lässt.
(wg. der niedrigeren Spannungen ???)
Wäre jetzt die Frage ob ein load von nem 6900er besser geht. Für meine MSi gibts aber kein 6900er-Bios bei TPU!?
Man weiss leider net wie die Spannung für den IF-Cache eingestellt wird.
(DaHell und Schwarzbacke/andybuc hatten ja schon mit 6900er load früher experimentiert)
edit3:
fclk 1550-->1600 funzt erstmal (evtl. war dann auch einfach nur mein altes WM-Setting zu scharf)
(vorsichtshalber auch Vram-Tuning=off)
3% mehr für lau ist ja schon mal Was! ... nützt am Ende aber auch nur Was wenn ich mit dem GPU-OCen wieder höher komme,
in annähernd alte Bereiche, ...mal schauen.
edit4:
GPU-Clock wieder im alten OCing-Bereich. (Vram-OCen geht auch bis 2140ST mit meiner abgesenkten MEM-Voltage)
Antwort 4 Likes
RedF
5,398 Kommentare 3,211 Likes
Das ja mal wieder was spannendes.
Habe die nächsten Wochen leider kaum Zeit vorm Rechner .
Aber das lässt sich ja nachholen.
12,239 Kommentare 24,275 Likes
Ja, mal schön testen und Zusammenfassen. Dann könnten wir daraus wieder ein Tut-Tut-Tutorial basteln :)
Antwort 4 Likes
RX480
Mir reichts für heute erstmal.
Vllt. findet sich noch ne andere nonXT mit mehr Zeit und Bedarf für höheren fclk.
Habe Da momentan keinen Plan wieweit man manuell ändern kann, und ob net ein load von nem 6900er besser/einfacher ist.
Gurdi
1,542 Kommentare 1,104 Likes
Bin auch dran, werde aber heute wenig schaffen wegen Baustelle. Evtl. heute abend mal das ein oder andere Fazit.
h
hellm
818 Kommentare 1,102 Likes
Danke fürs testen. Wenn es funzt ne 6900er PPT zu laden, welche eine höhere Fclk hat, und es funzt nicht dieselben Werte mit der 6800er PPT einzustellen, gibt es noch mehr Settings zu tweaken.
Ein kurzer Blick in den Hex-Editor.. und ja, da gibt es noch weitere Unterschiede unter "SECTION: DPM Config 1", und die ist ziemlich umfangreich. Mit Kurvenwerten usw, und leider kaum zuzuordnen zu den Frequenzen. Ich weiß genau was Memory ist, GFX dürfte das erste sein und SoC nicht allzu weit.. Fclk könnte ich möglicherweise nur per Trial&Error finden, die meisten anderen Frequenzen sowieso. Leider auch identische Taktraten, und nicht immer in derselben Reihenfolge auffindbar. Und es sind 13 Datenstrukturen, hab aber nur 11 Frequency Tables..
Der Teil ist in der mpt-Datei übrigens zwischen 0x4C2 und 0x62D zu finden, kann man auch mit Copy&Paste in nem Hex-Editor basteln. Das is ne Menge Zeug, wird ne ganze Weile dauern. Ich sollte wohl auch einfach alles mal änderbar machen, und mit den Erfahrungen aus der Beta können wir die Settings dann evtl auch zuordnen.
Ich genieße jetzt aber erstmal den Sommer..
Antwort 4 Likes
RX480
Das kann an an mir liegen, weil ich das Häkchen bei MemScaling draussen hatte = weniger V beim Vram!
Würde ich wie Gurdi auf 1,4V gehen, passts evtl. auf Anhieb.
und
Ne 6900 hat auch ein paar andere Bus-Clks als die nonXT, was evtl. auch zusammenpassen muss.
Vclk und Dclk scheinen bei der 6900 höher zu sein und natürlich die FclkBoostFreq.
dito
Gibts dann bei der 18Gbps auch noch mal andere Bus-Clks.(siehe Anhang)
(hatte mir mal zum Schauen das Bios der 18Gbps reingeladen)
sonic12434wtdsfxt4W$§%W$%
66 Kommentare 55 Likes
@RX480 dein 6800 Bild ist stock oder? Wunder mich grade das mein sapphire BIOS den SOC auf 1200 setzt und bei dir nur 970 steht. Sonst war alles gleich.
RX480
Jo, SOC-Takt ist abgesenkt.
Ich habe Einiges auf sparsam verstellt. (Voltage mal in dem Test mit ergänzt)
edit:
Kurz mal geschaut, und fclk um 10% angehoben von 1550 auf 1705 funzt.
(auch noch mit MemScaling=off stabil, ...reicht mir dann für 24/7)
edit2: Nachdem Gestern redF den Boost ca 50MHz mehr als den Max angehoben hat,
heute auch mal Boost = 1600 getestet (siehe Bild 3)
Vclk und Dclk auch angepasst! (dank Hinweis von Gurdi)
Achja ist im anderen Thread glaube ich untergegangen:
Um nach SPPT Änderungen nicht neustarten zu müssen eignet sich die restart.exe aus dem CustomResolutionUtil.
Könnte man ja irgendwo erwähnen, oder dort mal fragen ob wir das in MPT einbauen dürfen.
Edit: Seit der Beta von MPT sollte man es beim Treiber neustarten nicht offen lassen, ansonsten kann es sein das MPT sich komisch verhält. (fenster ziehen laggt)
Das war früher anders, jetzt passiert das nachdem ich mit mpt was änder, es offen lasse und dann den Treiber neustarte.
RedF
Bei mir hat das damit nicht immer so 100% geklappt.
Stimmt es gibt Fälle die einen Neustart erforden. Z.B. wenn man in ein Soft Powerlimit wie die 1025mv bei der 6800 rennt und die Karte runterregelt.
So lange ich die Limits eingehalten habe funktioniert es immer.
RedF
RX480
Habe die passenden Takte mal in der Siesta überschlafen und etwas erhöht:
Jetzt hat der SOC das selbe Verhältnis wie bei einer 6900, dort 2400=1200x2 SOC zu 1940 fclk.
Bei mir jetzt 2110=1055x2 SOC zu 1705 fclk, ... passt gut zu Vram 2112 = 2100effektiv.
Somit ist der eff. SOC-Takt (x2) immer schneller als beide Andere und kann das Bindeglied sein.
(x2 = Flankennutzung der Frequenz)
edit: habe mal das Bild gegen nen 24/7 Anwendungsfall SoTR@chill57fps getauscht
Ging jetzt 3mV niedriger im WM als heute früh.
Gurdi
Kannst du Mehrleistung aus dem Setting generieren?
RX480
Du brauchst nur bei Hades im Luxx schauen, da war bereits fclk 1550-->1600 für 18,5k im TS gut.
ca. 100pts+ ggü. seinem letzten highScore
Mal schauen, ob Er sich noch zu fclk 1705 oder 1940 überreden lässt.
Selber hab ich leider netmehr TS auf der Platte.(mein W10+Sys ist momentan auch net wirklich ideal fürs Benchen)
(hab letzte Woche mit Benchen aufgehört nach zuviel Crashs und W10 chkdsk Anforderung, um das kaputte Dateisystem zu reparieren)
RedF
Also fclk bei max auf 1600?
Den boost kann ich danach ja lassen wie er ist wenn er ein zweiter min fclk ist.
Bei mir hat fclk von den 1940 auf 2000 im TS nichts gebracht.
Kann ich den irgendwie auslesen?
RX480
die 1600 machen nur bei der nonXT Sinn, weils Da schon ne Erhöhung von 1550 auf 1600 ist
Bei ner XT evtl. von 1940 auf fclk1990 = safe. (bei SOC 1200x2=2400)
Weiss net, ob bei Dir auch SOC 1990/1940 x1200= 1231 gänge !?
..um das Verhältnis beizubehalten
Zuviel mehr fclk brachte bei Darkearth auch nichts, wurde dann langsamer.
RedF
Ja war nur als Beispiel zum Verständnis.
