Arctic
MSI
P12 PWM PST RGB 0dB
MEG Silent Gale P12
27.5 mm
159 g
209 g
0.7 W
1.4 W
48.8 CFM
56.2 CFM
82.9 m³/h
95.5 m³/h
1.85 mmH2O
2.21 mmH2O
22.7 dBA
Grau
Halbtransparent
4.0 V
5.5 V
2.9 V
4.3 V
380 U/min
906 U/min
532 U/min
742 U/min
194 U/min
186 U/min
1985 U/min
1980 U/min
512 U/min
32.1 CFM
+3.2 %
31.1 CFM
23.9 CFM
+11.2 %
21.5 CFM
23.0 CFM
+4.3 %
22.1 CFM
22.1 CFM
+12.1 %
19.7 CFM
54.6 m³/h
+3.2 %
52.9 m³/h
40.7 m³/h
+11.2 %
36.6 m³/h
39.1 m³/h
+4.3 %
37.5 m³/h
37.5 m³/h
+12.3 %
33.4 m³/h
+12.3 %
0.91 mmH2O
+32.8 %
+32.8 %
+32.8 %
+12.5 %
0.09 hPa
+33.3 %
+33.3 %
+33.3 %
33.8
-7.7 %
31.2
31.6
-9.2 %
34.8
32.7
-5.5 %
34.6
32.1
-3.0 %
33.1
