Arctic
Lian Li
P12 PWM PST RGB 0dB
UNI FAN SL120 ARGB
159 g
232 g
800 U/min
1900 U/min
48.8 CFM
58.5 CFM
82.9 m³/h
99.5 m³/h
1.85 mmH2O
1.67 mmH2O
31.0 dBA
Grau
Silber
Halbtransparent
4.0 V
2.9 V
2.4 V
380 U/min
412 U/min
532 U/min
98 U/min
1985 U/min
1828 U/min
32.1 CFM
+38.3 %
23.2 CFM
23.9 CFM
+35.2 %
17.7 CFM
23.0 CFM
+45.4 %
15.8 CFM
22.1 CFM
+44.2 %
15.3 CFM
54.6 m³/h
+38.2 %
39.5 m³/h
40.7 m³/h
+35.2 %
30.1 m³/h
39.1 m³/h
+45.3 %
26.9 m³/h
37.5 m³/h
+44.2 %
26.0 m³/h
+102.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+100.0 %
+50.0 %
+50.0 %
+50.0 %
33.8
-12.9 %
38.8
31.6
-13.9 %
36.7
32.7
-9.4 %
36.1
32.1
-7.2 %
34.6
