Arctic
Noctua
P12 PWM PST RGB 0dB
NF-A14 FLX
159 g
210 g
900 U/min
1200 U/min
48.8 CFM
68.0 CFM
82.9 m³/h
115.5 m³/h
1.85 mmH2O
1.51 mmH2O
19.2 dBA
Beige
Grau
Braun
Halbtransparent
Braun
4.0 V
4.6 V
2.9 V
4.2 V
380 U/min
381 U/min
532 U/min
469 U/min
1985 U/min
1199 U/min
32.1 CFM
+66.5 %
53.5 CFM
23.9 CFM
+37.6 %
33.0 CFM
23.0 CFM
+37.6 %
31.7 CFM
22.1 CFM
+36.5 %
30.1 CFM
54.6 m³/h
+66.5 %
90.9 m³/h
40.7 m³/h
+37.6 %
56.0 m³/h
39.1 m³/h
+37.6 %
53.8 m³/h
37.5 m³/h
+36.5 %
51.2 m³/h
+12.3 %
0.91 mmH2O
+49.2 %
0.91 mmH2O
+22.0 %
+103.3 %
0.30 mmH2O
+12.5 %
0.09 hPa
+50.0 %
0.09 hPa
+20.0 %
+100.0 %
0.03 hPa
33.8
-1.2 %
34.2
31.6
-25.8 %
42.6
32.7
-19.9 %
40.8
32.1
-19.5 %
39.9
