Blacknoise
Lian Li
B12x-PS-BL PWM ARGB
UNI FAN SL-INF 120
120 g
210 g
1500 U/min
2100 U/min
3.0 W
58.1 CFM
61.3 CFM
98.7 m³/h
104.1 m³/h
1.80 mmH2O
2.66 mmH2O
21.2 dBA
29.0 dBA
3.3 V
3.5 V
386 U/min
913 U/min
570 U/min
742 U/min
290 U/min
298 U/min
1491 U/min
2134 U/min
886 U/min
36.6 CFM
+22.2 %
30.0 CFM
23.5 CFM
+1.3 %
23.8 CFM
23.9 CFM
+11.2 %
21.5 CFM
22.8 CFM
+2.1 %
22.3 CFM
62.2 m³/h
+22.2 %
50.9 m³/h
40.0 m³/h
+1.2 %
40.5 m³/h
39.8 m³/h
+8.7 %
36.6 m³/h
38.7 m³/h
+2.1 %
37.9 m³/h
1.12 mmH2O
+57.7 %
0.71
0.71
+19.6 %
0.51 mmH2O
+39.2 %
0.51 mmH2O
0.11 hPa
+58.0 %
+0.5 %
+20.0 %
+40.0 %
38.7
-15.8 %
32.6
37.9
-11.6 %
33.5
39.1
-16.6 %
32.6
37
-9.5 %
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
