Blacknoise
Cooler Master
B12x-PS-BL PWM ARGB
Sickleflow 140 ARGB
120 g
195 g
650 U/min
1500 U/min
1400 U/min
58.1 CFM
67.0 CFM
98.7 m³/h
113.8 m³/h
1.80 mmH2O
2.25 mmH2O
21.2 dBA
27.0 dBA
Halbtransparent
3.3 V
5.5 V
2.9 V
386 U/min
599 U/min
570 U/min
495 U/min
1491 U/min
1374 U/min
36.6 CFM
+23.8 %
45.3 CFM
23.5 CFM
+19.2 %
28.1 CFM
23.9 CFM
+8.9 %
26.1 CFM
22.8 CFM
+18.6 %
27.0 CFM
62.2 m³/h
+23.8 %
77.0 m³/h
40.0 m³/h
+19.3 %
47.7 m³/h
39.8 m³/h
+11.3 %
44.3 m³/h
38.7 m³/h
+18.6 %
45.9 m³/h
1.12 mmH2O
+124.0 %
+42.0 %
+22.0 %
+42.0 %
0.11 hPa
+120.0 %
+40.0 %
+20.0 %
+40.0 %
38.7
-8.3 %
35.5
37.9
-1.8 %
37.2
39.1
-16.1 %
32.8
37
-9.5 %
33.5
