Blacknoise
Noctua
B12x-PS-BL PWM ARGB
NF-A14 FLX
120 g
210 g
900 U/min
1500 U/min
1200 U/min
58.1 CFM
68.0 CFM
98.7 m³/h
115.5 m³/h
1.80 mmH2O
1.51 mmH2O
21.2 dBA
19.2 dBA
Beige
Braun
Braun
3.3 V
4.6 V
4.2 V
386 U/min
381 U/min
570 U/min
469 U/min
1491 U/min
1199 U/min
36.6 CFM
+46.2 %
53.5 CFM
23.5 CFM
+40.0 %
33.0 CFM
23.9 CFM
+32.2 %
31.7 CFM
22.8 CFM
+32.3 %
30.1 CFM
62.2 m³/h
+46.1 %
90.9 m³/h
40.0 m³/h
+40.0 %
56.0 m³/h
39.8 m³/h
+35.2 %
53.8 m³/h
38.7 m³/h
+32.3 %
51.2 m³/h
1.12 mmH2O
+23.1 %
0.91 mmH2O
+28.2 %
0.91 mmH2O
+22.0 %
+136.7 %
0.30 mmH2O
0.11 hPa
+22.2 %
0.09 hPa
+28.6 %
0.09 hPa
+20.0 %
+133.3 %
0.03 hPa
38.7
-11.6 %
34.2
37.9
-11.0 %
42.6
39.1
-4.2 %
40.8
37
-7.3 %
39.9
