Arctic
Lian Li
P12 PWM
Uni Fan AL V2 120
28 mm
139 g
240 g
200 U/min
250 U/min
1800 U/min
0.7 W
2.1 W
56.3 CFM
77.3 CFM
131.3 m³/h
2.20 mmH2O
2.97 mmH2O
28.7 dBA
Einzelreview
Silber
3.0 V
3.0 V
207 U/min
762 U/min
547 U/min
749 U/min
297 U/min
198 U/min
1748 U/min
820 U/min
33.5 CFM
+43.7 %
48.2 CFM
23.2 CFM
+73.0 %
40.2 CFM
23.0 CFM
+30.8 %
30.1 CFM
21.5 CFM
+91.3 %
41.2 CFM
57.0 m³/h
+43.7 %
81.9 m³/h
39.5 m³/h
+72.9 %
68.3 m³/h
39.1 m³/h
+30.8 %
51.1 m³/h
36.6 m³/h
+91.3 %
70.0 m³/h
+246.7 %
1.73 mmH2O
+150.8 %
1.53 mmH2O
+104.0 %
1.02 mmH2O
+167.2 %
1.63 mmH2O
+240.0 %
0.17 hPa
+150.0 %
0.15 hPa
+100.0 %
+166.7 %
0.16 hPa
36.7
-14.2 %
31.5
34.7
-16.1 %
29.1
34.7
-12.1 %
30.5
34.4
-12.5 %
30.1
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
