Arctic
Lian Li
P12 PWM
UNI FAN SL-INF 120
139 g
210 g
200 U/min
1800 U/min
2100 U/min
3.0 W
56.3 CFM
61.3 CFM
104.1 m³/h
2.20 mmH2O
2.66 mmH2O
29.0 dBA
Silber
3.5 V
3.0 V
207 U/min
913 U/min
547 U/min
742 U/min
290 U/min
298 U/min
1748 U/min
2134 U/min
886 U/min
33.5 CFM
+12.0 %
30.0 CFM
23.2 CFM
+2.6 %
23.8 CFM
23.0 CFM
+6.8 %
21.5 CFM
21.5 CFM
+3.6 %
22.3 CFM
57.0 m³/h
+12.0 %
50.9 m³/h
39.5 m³/h
+2.5 %
40.5 m³/h
39.1 m³/h
+6.8 %
36.6 m³/h
36.6 m³/h
+3.6 %
37.9 m³/h
+42.0 %
+16.4 %
+2.0 %
0.51 mmH2O
+19.6 %
0.51 mmH2O
+39.3 %
+16.0 %
+0.0 %
+20.0 %
36.7
-11.2 %
32.6
34.7
-3.5 %
33.5
34.7
-6.1 %
32.6
34.4
-2.6 %
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
