Arctic
P12 PWM
Silent Wings 3
139 g
137 g
200 U/min
150 U/min
1800 U/min
1450 U/min
56.3 CFM
50.5 CFM
85.8 m³/h
2.20 mmH2O
1.79 mmH2O
16.4 dBA
Silber
4.1 V
3.0 V
3.9 V
207 U/min
547 U/min
206 U/min
244 U/min
1748 U/min
1411 U/min
33.5 CFM
+48.8 %
22.5 CFM
23.2 CFM
+16.8 %
19.9 CFM
23.0 CFM
+33.5 %
17.2 CFM
21.5 CFM
+28.4 %
16.8 CFM
57.0 m³/h
+48.8 %
38.3 m³/h
39.5 m³/h
+16.9 %
33.8 m³/h
39.1 m³/h
+33.4 %
29.3 m³/h
36.6 m³/h
+28.4 %
28.5 m³/h
+102.0 %
1.01 mmH2O
+16.4 %
+42.0 %
+22.0 %
+98.1 %
+16.0 %
+39.3 %
+22.4 %
36.7
-0.3 %
36.8
34.7
-17.0 %
41.8
34.7
-14.3 %
40.5
34.4
-15.3 %
40.6
