Arctic
Arctic
P12 PWM
P14 PWM
139 g
194 g
200 U/min
200 U/min
1800 U/min
1700 U/min
56.3 CFM
72.8 CFM
123.8 m³/h
2.20 mmH2O
2.40 mmH2O
Silber
3.8 V
3.0 V
207 U/min
395 U/min
547 U/min
481 U/min
1748 U/min
1733 U/min
33.5 CFM
+36.2 %
45.7 CFM
23.2 CFM
+16.5 %
27.1 CFM
23.0 CFM
+12.0 %
25.8 CFM
21.5 CFM
+25.4 %
27.0 CFM
57.0 m³/h
+36.1 %
77.6 m³/h
39.5 m³/h
+16.5 %
46.0 m³/h
39.1 m³/h
+12.0 %
43.8 m³/h
36.6 m³/h
+25.4 %
45.9 m³/h
+20.0 %
0.60 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+20.0 %
+50.0 %
+25.0 %
+50.0 %
36.7
-16.3 %
30.7
34.7
-12.4 %
30.4
34.7
-13.5 %
30
34.4
-11.0 %
30.6
