Cooler Master
Arctic
Masterfan MF120 Halo
P12 PWM
180 g
139 g
650 U/min
200 U/min
1800 U/min
1800 U/min
47.2 CFM
56.3 CFM
2.20 mmH2O
30.0 dBA
Grau
Silber
Halbtransparent
3.3 V
3.0 V
166 U/min
207 U/min
590 U/min
547 U/min
1792 U/min
1748 U/min
24.8 CFM
+35.4 %
33.5 CFM
19.9 CFM
+16.8 %
23.2 CFM
20.2 CFM
+13.7 %
23.0 CFM
17.2 CFM
+24.9 %
21.5 CFM
42.1 m³/h
+35.4 %
57.0 m³/h
33.8 m³/h
+16.9 %
39.5 m³/h
31.4 m³/h
+24.5 %
39.1 m³/h
29.3 m³/h
+24.9 %
36.6 m³/h
0.40 mmH2O
+25.0 %
+32.8 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
+25.0 %
+33.3 %
+25.0 %
+50.0 %
37.8
-2.9 %
36.7
36.4
-4.7 %
34.7
36.5
-4.9 %
34.7
35.6
-3.4 %
34.4
