Cooler Master
Lian Li
Masterfan MF120 Halo
UNI FAN SL-INF 120
180 g
210 g
650 U/min
1800 U/min
2100 U/min
3.0 W
47.2 CFM
61.3 CFM
104.1 m³/h
2.66 mmH2O
30.0 dBA
29.0 dBA
Grau
Halbtransparent
3.3 V
3.5 V
166 U/min
913 U/min
590 U/min
742 U/min
290 U/min
298 U/min
1792 U/min
2134 U/min
886 U/min
24.8 CFM
+20.9 %
30.0 CFM
19.9 CFM
+19.8 %
23.8 CFM
20.2 CFM
+6.4 %
21.5 CFM
17.2 CFM
+29.4 %
22.3 CFM
42.1 m³/h
+20.9 %
50.9 m³/h
33.8 m³/h
+19.8 %
40.5 m³/h
31.4 m³/h
+16.6 %
36.6 m³/h
29.3 m³/h
+29.4 %
37.9 m³/h
0.40 mmH2O
+77.5 %
+14.1 %
0.40 mmH2O
+27.5 %
0.51 mmH2O
0.40 mmH2O
+27.5 %
0.51 mmH2O
+74.1 %
+14.9 %
+25.0 %
+25.0 %
37.8
-13.8 %
32.6
36.4
-8.0 %
33.5
36.5
-10.7 %
32.6
35.6
-5.9 %
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
