Cooler Master
Sharkoon
Masterfan MF120 Halo
Silent Storm PWM RGB Fan
180 g
168 g
650 U/min
400 U/min
1800 U/min
1400 U/min
2.6 W
47.2 CFM
121.9 m³/h
1.47 mmH2O
30.0 dBA
34.7 dBA
Grau
Halbtransparent
3.3 V
1.9 V
166 U/min
506 U/min
590 U/min
54 U/min
1792 U/min
1413 U/min
440 U/min
24.8 CFM
+65.8 %
41.1 CFM
19.9 CFM
+60.6 %
31.9 CFM
20.2 CFM
+51.5 %
30.7 CFM
17.2 CFM
+94.9 %
33.6 CFM
42.1 m³/h
+65.8 %
69.8 m³/h
33.8 m³/h
+60.7 %
54.3 m³/h
31.4 m³/h
+65.9 %
52.1 m³/h
29.3 m³/h
+94.9 %
57.1 m³/h
0.40 mmH2O
+102.5 %
+14.1 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+27.5 %
0.51 mmH2O
+100.0 %
+14.3 %
+75.0 %
+25.0 %
37.8
-13.8 %
32.6
36.4
-10.2 %
32.7
36.5
-9.0 %
33.2
35.6
-9.8 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
