Cooler Master
Sharkoon
Masterfan MF120 Halo
Silent Storm PWM RGB Fan
180 g
135 g
650 U/min
400 U/min
1800 U/min
1400 U/min
2.2 W
47.2 CFM
93.6 m³/h
30.0 dBA
20.4 dBA
Grau
Halbtransparent
3.3 V
3.6 V
166 U/min
585 U/min
590 U/min
561 U/min
1792 U/min
1374 U/min
513 U/min
24.8 CFM
+37.3 %
34.0 CFM
19.9 CFM
+2.1 %
19.5 CFM
20.2 CFM
+20.7 %
24.4 CFM
17.2 CFM
+24.9 %
21.5 CFM
42.1 m³/h
+37.3 %
57.8 m³/h
33.8 m³/h
+2.1 %
33.1 m³/h
31.4 m³/h
+32.2 %
41.5 m³/h
29.3 m³/h
+24.9 %
36.6 m³/h
0.40 mmH2O
+77.5 %
+32.8 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+75.0 %
+33.3 %
+50.0 %
+50.0 %
37.8
-16.1 %
31.7
36.4
-19.8 %
29.2
36.5
-24.7 %
27.5
35.6
-23.9 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
