Cooler Master
Fractal
Masterfan MF120 Halo
Prisma AL-12PWM
180 g
167 g
650 U/min
500 U/min
1800 U/min
1.9 W
47.2 CFM
85.7 CFM
145.7 m³/h
2.80 mmH2O
30.0 dBA
32.0 dBA
Grau
Halbtransparent
3.3 V
4.5 V
3.8 V
166 U/min
443 U/min
590 U/min
269 U/min
1792 U/min
2001 U/min
550 U/min
24.8 CFM
+27.6 %
31.6 CFM
19.9 CFM
+4.1 %
20.7 CFM
20.2 CFM
+2.9 %
20.8 CFM
17.2 CFM
+14.7 %
19.8 CFM
42.1 m³/h
+27.6 %
53.7 m³/h
33.8 m³/h
+4.1 %
35.2 m³/h
31.4 m³/h
+12.7 %
35.4 m³/h
29.3 m³/h
+14.7 %
33.6 m³/h
0.40 mmH2O
+102.5 %
+14.1 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
+100.0 %
+14.3 %
+75.0 %
+50.0 %
37.8
-6.1 %
35.5
36.4
-7.7 %
33.6
36.5
-12.6 %
31.9
35.6
-19.7 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
