Cooler Master
Masterfan MF120 Halo
Light Wings 140 PWM HS
180 g
266 g
650 U/min
250 U/min
1800 U/min
2200 U/min
1.9 W
4.7 W
47.2 CFM
71.7 CFM
121.8 m³/h
2.30 mmH2O
30.0 dBA
31.0 dBA
Grau
Halbtransparent
3.3 V
3.0 V
166 U/min
565 U/min
590 U/min
556 U/min
1792 U/min
2264 U/min
241 U/min
24.8 CFM
+62.1 %
40.1 CFM
19.9 CFM
+22.8 %
24.4 CFM
20.2 CFM
+11.1 %
22.5 CFM
17.2 CFM
+40.0 %
24.1 CFM
42.1 m³/h
+62.0 %
68.2 m³/h
33.8 m³/h
+22.8 %
41.5 m³/h
31.4 m³/h
+21.7 %
38.2 m³/h
29.3 m³/h
+39.9 %
41.0 m³/h
0.40 mmH2O
+357.5 %
1.83 mmH2O
+32.8 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+350.0 %
0.18 hPa
+33.3 %
+50.0 %
+50.0 %
37.8
-32.5 %
25.5
36.4
-26.6 %
26.7
36.5
-29.6 %
25.7
35.6
-28.4 %
25.5
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
