Cooler Master
Scythe
Masterfan MF120 Halo
Kaze Flex 120 ARGB FAN
180 g
205 g
Grau
Halbtransparent
Halbtransparent
3.3 V
3.3 V
166 U/min
729 U/min
590 U/min
742 U/min
1792 U/min
1830 U/min
289 U/min
5.2 W
24.8 CFM
+52.8 %
37.8 CFM
19.9 CFM
+34.9 %
26.8 CFM
20.2 CFM
+26.8 %
25.7 CFM
17.2 CFM
+41.6 %
24.4 CFM
42.1 m³/h
+52.7 %
64.3 m³/h
33.8 m³/h
+34.9 %
45.6 m³/h
31.4 m³/h
+38.9 %
43.6 m³/h
29.3 m³/h
+41.6 %
41.5 m³/h
0.40 mmH2O
+102.5 %
+12.3 %
0.91 mmH2O
0.40 mmH2O
+127.5 %
0.91 mmH2O
0.40 mmH2O
+127.5 %
0.91 mmH2O
+100.0 %
+12.5 %
0.09 hPa
+125.0 %
0.09 hPa
+125.0 %
0.09 hPa
37.8
-7.1 %
40.7
36.4
-5.2 %
38.4
36.5
-4.9 %
38.4
35.6
-2.5 %
36.5
  • 742
  • 942
  • 1142
  • 1342
  • 1542
  • 1742
