Cooler Master
Asus
Masterfan MF120 Halo
180 g
145 g
650 U/min
250 U/min
1800 U/min
1800 U/min
47.2 CFM
62.5 CFM
106.2 m³/h
3.07 mmH2O
30.0 dBA
22.5 dBA
Grau
Halbtransparent
3.3 V
166 U/min
409 U/min
590 U/min
419 U/min
208 U/min
129 U/min
1792 U/min
1778 U/min
308 U/min
24.8 CFM
+3.4 %
23.9 CFM
19.9 CFM
+6.3 %
18.7 CFM
20.2 CFM
+9.5 %
18.5 CFM
17.2 CFM
+2.7 %
17.7 CFM
42.1 m³/h
+3.4 %
40.7 m³/h
33.8 m³/h
+6.3 %
31.8 m³/h
31.4
31.4
29.3 m³/h
+2.7 %
30.1 m³/h
0.40 mmH2O
+129.4 %
0.92 mmH2O
+13.3 %
0.92 mmH2O
0.40 mmH2O
+103.9 %
0.82 mmH2O
0.40 mmH2O
+78.5 %
+125.0 %
0.09 hPa
+12.5 %
0.09 hPa
+100.0 %
+75.0 %
37.8
-8.5 %
34.6
36.4
-6.4 %
38.9
36.5
-4.9 %
38.4
35.6
-7.3 %
38.4
