Cooler Master
Lian Li
Masterfan MF120 Halo
UNI FAN SL120 ARGB
180 g
232 g
650 U/min
800 U/min
1800 U/min
1900 U/min
47.2 CFM
58.5 CFM
99.5 m³/h
1.67 mmH2O
30.0 dBA
31.0 dBA
Grau
Silber
Halbtransparent
3.3 V
2.4 V
166 U/min
412 U/min
590 U/min
98 U/min
1792 U/min
1828 U/min
24.8 CFM
+6.6 %
23.2 CFM
19.9 CFM
+12.3 %
17.7 CFM
20.2 CFM
+27.9 %
15.8 CFM
17.2 CFM
+12.7 %
15.3 CFM
42.1 m³/h
+6.6 %
39.5 m³/h
33.8 m³/h
+12.3 %
30.1 m³/h
31.4 m³/h
+16.7 %
26.9 m³/h
29.3 m³/h
+12.7 %
26.0 m³/h
0.4
0.4
+102.5 %
0.40 mmH2O
0.4
0.4
0.4
0.4
0.04
0.04
+100.0 %
0.04
0.04
0.04
0.04
37.8
-2.6 %
38.8
36.4
-0.8 %
36.7
36.5
-1.1 %
36.1
35.6
-2.8 %
34.6
