Cooler Master
Corsair
Masterfan MF120 Halo
LL140 RGB
180 g
210 g
650 U/min
600 U/min
1800 U/min
1300 U/min
47.2 CFM
51.5 CFM
87.5 m³/h
1.52 mmH2O
30.0 dBA
25.0 dBA
Grau
Halbtransparent
Halbtransparent
3.3 V
2.9 V
166 U/min
226 U/min
590 U/min
378 U/min
1792 U/min
1319 U/min
24.8 CFM
+81.8 %
45.0 CFM
19.9 CFM
+42.6 %
28.4 CFM
20.2 CFM
+21.0 %
24.5 CFM
17.2 CFM
+53.3 %
26.4 CFM
42.1 m³/h
+81.7 %
76.5 m³/h
33.8 m³/h
+42.6 %
48.2 m³/h
31.4 m³/h
+32.5 %
41.6 m³/h
29.3 m³/h
+53.2 %
44.9 m³/h
0.40 mmH2O
+50.0 %
0.60 mmH2O
+62.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
+50.0 %
+60.0 %
+25.0 %
+50.0 %
37.8
-6.6 %
35.3
36.4
-1.4 %
36.9
36.5
-6.8 %
34
35.6
-2.2 %
34.8
