Cooler Master
Noctua
Masterfan MF120 Halo
NF-A14 FLX
180 g
210 g
650 U/min
900 U/min
1800 U/min
1200 U/min
47.2 CFM
68.0 CFM
115.5 m³/h
1.51 mmH2O
30.0 dBA
19.2 dBA
Beige
Grau
Braun
Halbtransparent
Braun
3.3 V
4.6 V
4.2 V
166 U/min
381 U/min
590 U/min
469 U/min
1792 U/min
1199 U/min
24.8 CFM
+116.0 %
53.5 CFM
19.9 CFM
+65.7 %
33.0 CFM
20.2 CFM
+56.5 %
31.7 CFM
17.2 CFM
+74.8 %
30.1 CFM
42.1 m³/h
+115.9 %
90.9 m³/h
33.8 m³/h
+65.7 %
56.0 m³/h
31.4 m³/h
+71.3 %
53.8 m³/h
29.3 m³/h
+74.7 %
51.2 m³/h
0.40 mmH2O
+127.5 %
0.91 mmH2O
+12.3 %
0.91 mmH2O
0.40 mmH2O
+25.0 %
0.40 mmH2O
+33.3 %
0.30 mmH2O
+125.0 %
0.09 hPa
+12.5 %
0.09 hPa
+25.0 %
+33.3 %
0.03 hPa
37.8
-9.5 %
34.2
36.4
-14.6 %
42.6
36.5
-10.5 %
40.8
35.6
-10.8 %
39.9
