Cooler Master
Thermalright
Masterfan MF120 Halo
TL-B12 Extreme
25.6 mm
180 g
215 g
650 U/min
550 U/min
1800 U/min
3150 U/min
1.0 W
4.2 W
47.2 CFM
112.0 CFM
190.3 m³/h
5.00 mmH2O
30.0 dBA
40.5 dBA
Grau
Rot, Weiß
Halbtransparent
3.3 V
1.8 V
1.4 V
166 U/min
293 U/min
590 U/min
163 U/min
1792 U/min
2857 U/min
554 U/min
24.8 CFM
+27.6 %
31.6 CFM
19.9 CFM
+19.3 %
23.7 CFM
20.2 CFM
+10.2 %
22.3 CFM
17.2 CFM
+22.2 %
21.1 CFM
42.1 m³/h
+27.6 %
53.7 m³/h
33.8 m³/h
+19.2 %
40.3 m³/h
31.4 m³/h
+20.7 %
37.9 m³/h
29.3 m³/h
+22.2 %
35.8 m³/h
0.40 mmH2O
+77.5 %
+14.1 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+77.5 %
+75.0 %
+14.3 %
+100.0 %
+75.0 %
37.8
-14.3 %
32.4
36.4
-14.6 %
31.1
36.5
-11.0 %
32.5
35.6
-14.3 %
30.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
