Cooler Master
EK
Masterfan MF120 Halo
Vardar X3M D-RGB
27.5 mm
180 g
210 g
650 U/min
500 U/min
1800 U/min
2200 U/min
2.2 W
47.2 CFM
67.0 CFM
114.0 m³/h
2.75 mmH2O
30.0 dBA
34.2 dBA
Grau
Halbtransparent
3.3 V
2.7 V
2.3 V
166 U/min
472 U/min
590 U/min
418 U/min
666 U/min
367 U/min
1792 U/min
2161 U/min
24.8 CFM
+47.1 %
36.4 CFM
19.9 CFM
+9.8 %
21.8 CFM
20.2 CFM
+0.6 %
20.4 CFM
17.2 CFM
+11.3 %
19.2 CFM
42.1 m³/h
+47.0 %
61.9 m³/h
33.8 m³/h
+9.8 %
37.1 m³/h
31.4 m³/h
+10.2 %
34.6 m³/h
29.3 m³/h
+11.3 %
32.6 m³/h
0.40 mmH2O
+230.0 %
1.32 mmH2O
+32.8 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
+225.0 %
0.13 hPa
+33.3 %
+25.0 %
+50.0 %
37.8
-20.9 %
29.9
36.4
-7.1 %
33.8
36.5
-22.5 %
28.3
35.6
-20.2 %
28.4
  • 666
  • 866
  • 1066
  • 1266
  • 1466
  • 1666
  • 1866
  • 2066
