Cooler Master
Pure Wings 2
Masterfan MF120 Halo
93 g
180 g
300 U/min
650 U/min
1500 U/min
1800 U/min
51.4 CFM
47.2 CFM
1.25 mmH2O
20.2 dBA
30.0 dBA
Grau
Halbtransparent
3.3 V
202 U/min
166 U/min
324 U/min
590 U/min
1488 U/min
1792 U/min
31.5 CFM
+27.1 %
24.8 CFM
22.1 CFM
+11.0 %
19.9 CFM
21.3 CFM
+5.2 %
20.2 CFM
20.8 CFM
+20.8 %
17.2 CFM
53.5 m³/h
+27.1 %
42.1 m³/h
37.5 m³/h
+10.9 %
33.8 m³/h
36.2 m³/h
+15.3 %
31.4 m³/h
35.4 m³/h
+20.8 %
29.3 m³/h
+77.5 %
0.40 mmH2O
+14.1 %
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+75.0 %
+14.3 %
+25.0 %
+25.0 %
38.2
-1.0 %
37.8
36.7
-0.8 %
36.4
36
-1.4 %
36.5
36.2
-1.7 %
35.6
